Moggy wrote:Thankyou bigdog!![]()
All answers are on that page. I will summarise...
This is a 1.6 open diff with a smooth case:
And this is a 1.6 viscous LSD (torsen) finned case from the right:
And left:
You can see the way to tell the difference is by the tangs on the stub shaft flange where the half shafts bolt in. The open diffs have eight regular tangs (four with studs) on both sides while the torsens have different tangs on the left and right shaped as circled above.
It turns out I have a smooth case torsen which surprises me slightly as my car was one of the first Eunos Roadsters made (July '89, #100225) and I thought that all the first mx5's had open diffs...
Cool...
Moggy - a VLSD (viscous fluid) is a different beast to a TorSen (Torque Sensing) diff. The 1600 only VLSD was quite widely optioned on the Eunos Roadster. The 1800 saw the use of the much stronger TorSen and is externally indistinguishable from the 1800 open diff.
