Okibi's Electronic Boot Release Saga
Postby Okibi » Thu May 18, 2006 10:13 pm
Cable Plastic Sheath Thingo (From a Bike Brake Cable)
One end is stripped to fit inside the end of the Jcar Cable Actuator
Pilot Hole For Cable Guide
Cable Guide and Nut (bike brake)
Cable Guide and Nut Attached
This nut and bolt is part of the Jcar Kit, it attaches the new wire to the factory boot release
The Fuse Holder with the 7.5 fuse that blew (without the relay)
I still need to finish the bracket to hold the actuator then make up some neat electrical cables and mount the relay.
bigdog
King of the kennel
Postby bigdog » Thu May 18, 2006 10:24 pm
Well done Okibi! Would have been simpler to buy an NB with remote boot release already fitted though :P
Postby Okibi » Thu May 18, 2006 10:31 pm
not on my budget it wouldn't :cry:
Postby Okibi » Fri May 19, 2006 1:17 am
Bracket to mount the actuator on the passenger side of the lock mechanism (vertically cable pointing down) so it won't get in the way of the rod to the boot lock.
To mount the actuator on the dodgy Jcar bracket thing as close to the boot locking mechanism as possible I chopped about 1cm off each bolt so they didn’t stick out.
Relay all wired up
All the trimming fits on perfectly.
Done :mrgreen:
