aftermarket ECU on a non turbo car
Steve 818
Postby Steve 818 » Sat Apr 15, 2006 11:34 pm
Sean wrote:
Those figures have been floating around for years. I've heard them from day one of being an MX5 driver with net access. Remember those figures are based on standard ECU and standard fuelling. I've never seen the same car run back to back on any dyno in Australia to prove the results in our conditions, certainly I advanced my timing to 14 degrees and thought i had an improvement, but it could have easily been a placebo effect.
Last improvement I made to my car gained 24h (dyno proven) and I thought it felt less powerful! Smooth delivery of power will likely make you think you have less, but if it picks up some at the top end and looses some at the bottom you may think you MUCH more power, when effectively the car will be slower to top speed.
For this reason I'd take the above figures with a grain of salt over here in Australia cause ther's no real concrete evidence to support them.
The point of using those figures was because they are 'known' and that a person with an aftermarket ECU has the benefit of getting both the low down torque and the upper power without having the compromises associated with the factory ECU.
Your example of making 24h with your programmable ECU is the same point that I was making. Any decent aftermarket ECU can be tuned to produce better power than a standard ECU.
Sean
Postby Sean » Sat Apr 15, 2006 11:38 pm
Ah OK, missed you point dude.
Certainly there are gains to be found with a tuneable ECU 8)
My 24hp was not a direct result of ECU, teh car already had teh ECU and other mods, we changed cams and picked up considerable power across teh rev range.
I guess that's another advantage of aftermarket ECU, leave your options open for further mods in the future.
Steve 818
Postby Steve 818 » Sun Apr 16, 2006 12:11 am
I'm also getting better fuel consumption with my programmable ECU running my new 1.8 over how the factory ECU used to run my old 1.6. And that's just with seat of the pants tuning.
Once I get it on a dyno I should be able to further improve the consumption at both cruising revs and high rpm and get some decent power out of it.
Hell the new ECU will probably end up paying for itself within a couple of years with the way that petrol prices are increasing....
Astroboysoup
Postby Astroboysoup » Sun Apr 16, 2006 5:09 pm
definately
fuel price here in adelaide are just baout to hit the $1.50 mark as supplies become scarce.
I can't wait to get my emanage.
AustCars.net - It's like Facebook but for cars!
Steve 818
Postby Steve 818 » Sun Apr 16, 2006 5:23 pm
Astroboysoup wrote:definately
If you decide to go turbo in the future a Emanage won't be able to do everything that you need. You would be better off getting a 'decent' ECU from the start.
Users browsing this forum: No registered users and 28 guests
