The Pupat wrote:THE REAL BORIS wrote:So, if I understand you correctly, if Chiptorque and Vishnu etc. claim more horsepower from a standard factory car by changing the engine management parameters and not any hardware, the factory could have done a better job, since both cannot be as good as each other?
I cannot agree with that; they are just different. The factory is more conservative on boost, timing etc. presumeably for longevity. But, the aftermarket guys get more power at the expense of something surely. So, why not have both?
As far as the factory offering more than one program, how are they going to have a base for warranty? All their cars are a compromise of some sort, to fit into a market niche.
The only place I can think of where there is little room for compromise (and cost is the least of their worries) is Formula One; how many choices do they have from the drivers' seats I wonder ...... ? IF it is more than one, then why?
Umm Sean is correct a proper tune will have no issues. This crap about needing 2 maps to get good low down driveability and bigger top end, I would imagine (unless something drastic has changed in the EXEDE in the last 2 years) that this has more to do with the limits of the EXEDE to adequately modify the computers parameters across the RPM range.
Anyway I hope this product lives up to your expecations, though personally if anyone played the "requires 2 maps to get good low-down driveability and high-top end" I would certainly not be letting the door catch me on the way out.
To the best of my knowledge the reason for two maps has NOTHING to do with low down driveability and power issues. Each MAP within the EXEDE has the same level of adjustability within the the standard computers parameters. It's absurd to suggest while I'm tootling around in 5th @ 60km/h I need to use one map then flick the switch when I wanna do 200km/h in 6th! There are few valid resons that this and many other computers have 1, 2, 3 & 4 maps but to have driveability on one and power on the other ain't one of those reasons.
I think VISHNU used to seperate maps in this strange fashion initialy to overcome their lack of experience with the EXEDE and nothing more.
