Lots of reading in this thread,
I've got 2 x na8 exhaust cams so I was going to do the in/ex cam mod but now I'm considering getting them reground.
Since these are bigger duration then the inlet cam hopeful there is more 'meat' for the regrind.
Im hoping to run a high compression (11-12:1) nonturbo 1.8 with biggish cams - something like Maruha racing 264 degree 10mm.
http://www.maruhamotors.co.jp/miata/parts/racingcam.html
Anyone have a regrind done close to these specs? The 33mm base circle should be fine as ive got SUBS coming and would have to shim them anyway.
Clive cams https://www.facebook.com/CliveCams/ quoted me about $350 to regrind them, but said they would have to measure them first to see if they could get the specs I want.
Anyone else here used clive cams?
Cost of CAMs
Re: Cost of CAMs
na6 progress thread - http://mx5cartalk.com/forum/viewtopic.php?f=57&t=68039
Re: Cost of CAMs
Not used Clive personally, but my GFs work use them fairly often on customer race cars.
Apparently they're great, and the guys there have a heap of knowledge (pretty sure Clive worked for wade cams before doing his own thing)
Clive are Also 10mins from my house.
Users browsing this forum: Bing [Bot] and 3 guests
