Subaru Upper Engine Cleaner review...
Re: Subaru Upper Engine Cleaner review...
Postby NitroDann » Sat Jul 23, 2011 11:00 pm
Maybe badbong needs to htfu?
Just maybe.
Im so keen I can hardly wait. Ill have 30 kilos less weight than ever before. 20 odd hp more than any other track day, new bushes, finally a god damned race seat in it, and some new r specs. Never tracked this car on them. no oil leaks either. Im sure theres more... More bracing. Getting so much work done while its out of rego.
Is there a september 4th thred yet?
Postby NitroDann » Sat Jul 23, 2011 11:02 pm
Ooh, Ooh.
New hawk blues, fully hektik brakes ducting and the cooling ducting too.
:D :D cant wait.
hamx5ter
Postby hamx5ter » Sun Jul 24, 2011 2:08 pm
Apu wrote:
Hjt wrote:As Dann said above, and yes i'm keen to do it next weekend if you are up for it.
ATM Sunday i'm doing some odd jobs with Victor AKA Badbong for his SP. But it's not a big sidetrack, i'll get some cans from the Suburu at Lindfield midweek :)
Count me in! Next Sunday should be OK!
I've been meaning to do this for ages now. So bring this on next sunday.
samx5
Postby samx5 » Thu Aug 18, 2011 1:03 pm
Just used half a can of this in the inlet manifold (sprayed past the open throttle butterfly), cranked over & waited for 10 minutes as per Dann's notes, then started and ran at moderate revs for a few minutes. Was a bit of whitish smoke on revving but not too bad, and smoke lasted for a minute or two. Car now revs smoother, feels less coarse, and the little stumble that the car had just off idle when taking off from rest is now gone. The idle speed was not affected. Stuff seems good, does have a positive effect on the running of the car. Have saved the other half of the can for before the next service. Now for the oil change today.
Was: 1988 Corolla 4A-GE Twin Cam, 1991 Laser TX3, 1995 Peugeot 306 S16, 2003 Astra Sri Turbo, 2007 SP23 Lux
Now:1999 NB8A, 2011 Outlander VR-X
slug_dub
Postby slug_dub » Thu Aug 18, 2011 3:33 pm
I just bought a can each for both our cars and will see how it goes. :)
gslender
Postby gslender » Thu Aug 18, 2011 6:50 pm
Cool. So what, you walk into Subaru service dept and ask for a can? How come SuperCheap/Repco/Autobahn etc don't stock something similar.... Or do they?
G
Dweezle
Postby Dweezle » Thu Aug 18, 2011 6:53 pm
Autoone/pro??? not sure which one at Chatswood, have a very similar product.
Can not quite remember the name but it was upper engine cleaner.
Can looked almost identical. Was about $15 a can from memory.
ALL MUSCLE CARS ARE CRAP
Jeremy Clarkson
samx5
Postby samx5 » Thu Aug 18, 2011 7:02 pm
gslender wrote:Cool. So what, you walk into Subaru service dept and ask for a can? How come SuperCheap/Repco/Autobahn etc don't stock something similar.... Or do they?
G
I bought it from Subaru spare parts in Adelaide. Yep, just ask for it, was $18.95.
SuperMazdaKart
Postby SuperMazdaKart » Thu Aug 18, 2011 9:39 pm
You can substitute the Subaru cleaner with CRC/Nulon throttle body cleaner instead. Costs less & you get a much bigger spray can. Same procedure essentially.
http://fordlaser.com/viewtopic.php?t=21496&highlight=decarb
Postby NitroDann » Thu Aug 18, 2011 10:24 pm
It REALLY isnt as good. Theres a reason your local mechanic buys boxes of the subaru stuff.
The foam allows it to hit every part of the manifold, and the chemicals are much more powerful.
slug_dub
Postby slug_dub » Tue Aug 23, 2011 5:35 pm
Well I'll certainly vouch that its made the engine seem to run smoother! Nice.
Idle speed did go up a bit so I adjusted it back. Now for subjecting the NA6 to the other can...
GP14
Postby GP14 » Tue Aug 23, 2011 8:29 pm
G
saw something similar at repco. I can't remember the name but the instructions were exactly the same as well as the can size. My next service I'll give it a go and let you know.
ivan
Postby ivan » Thu Sep 22, 2011 6:38 pm
I just tried this today too. Fair amount of smoke on first start up.
THEN...when i was spraying into the small inlet the little plastic tube that comes with the spray can popped off and i wasnt sure if it got sucked in to the manifold. Turned it off and took off the intake and opened up the throttle to take a look.
Couldn't see it in there so i sprayed a bit more in there before closing it back up and starting it again. If the plastic tube did indeed get sucked in there it must have just melted away as I didnt hear or feel anything funny...so i guess just be careful!
mx5lover
Postby mx5lover » Mon Dec 19, 2011 3:37 pm
I used it on my 5 today, when I nearly finished the half of can through the vacum hose, the nozzle tube was suddenly disappear. :(
But I couldn't find it around my engine. Is that any possiblity the tube was sucked into the intake manifold when I rev the engine?
spikes
Postby spikes » Mon Dec 19, 2011 4:11 pm
mx5lover wrote:I used it on my 5 today, when I nearly finished the half of can through the vacum hose, the nozzle tube was suddenly disappear. :(
Mine got sucked into the port, it ended up sitting just outside the intake ports in the head. I knew it had been sucked down so I decided to pull the intake manifold off to fish it out. And whilst at it, gave it a good and proper clean as well
Users browsing this forum: No registered users and 50 guests
