How many RWKW do you have with what mods?
rascal
Re: How many RWKW do you have with what mods?
Postby rascal » Wed Jul 09, 2014 10:54 pm
evil_weevil wrote:Just on that, as my car is no longer rego'd, how much difference would no cat converter make? If any?
Basically just noise.
I ran without cat for a year and then fitted a 200 cell one due to class reqs, and my power didn't change one bit..
Paulus
Postby Paulus » Thu Jul 10, 2014 10:41 am
If you end up tuning with an aftermarket ecu... You don't have to worry about Unburnt fuel killing your cat. Meow
td05-16g, megasquirt, custom zorst, msdroid tablet etc
JDMInfused
Postby JDMInfused » Wed Nov 12, 2014 9:23 am
71.9Kw atw
Fujtsubo 4-1 headers
Decat
Trust MX Catback
I was happy with that :)
JDM Infused
Sole Australian Distributors Of CarbonMiata Products!
Email:JDMInfused@gmail.com
speed
Postby speed » Wed Nov 12, 2014 5:32 pm
JDMInfused, good work and thanks for sharing :)
bartmanftw
Postby bartmanftw » Wed Nov 12, 2014 5:49 pm
I managed 70.4rwkw with my 200k km 1.6 motor with Uknown (possibly ebay?) 4-2-1 headers, stock exhaust, MS2 ecu, AFM delete and pod filter on the stock crossover pipe.
Since then I've bumped the timing up a fair bit and leaned the AFRs out as they were far too rich before so should be making a tad more power.
pcmx5
Postby pcmx5 » Fri Nov 14, 2014 6:47 pm
Now have 106.6 RWKW, dyno sheet to be posted on Dyno and lap times forum.
Peter.
fletchb
Postby fletchb » Fri Nov 14, 2014 10:43 pm
Same dyno over the years stock na8, 71kwatw, then headers, arc chamber plus intake, maruha cams and ecu 91kwatw, 12 months later, haltech big cams, high comp pistons bit of headwork, e85 jenvey throttlebodies, 126.3 atw, the only down side is I didn't read the rules properly for a certain class of racing so will put the normal throttlebody back on but still run e85 and hope I don't lose to much :lol:
Postby fastfreddygassit » Sat Nov 15, 2014 11:48 am
pcmx5 wrote:Now have 106.6 RWKW, dyno sheet to be posted on Dyno and lap times forum.Peter.
Swile
Postby Swile » Wed Jan 07, 2015 12:57 pm
170kw at the wheels in a 04 SE. It has AEM Intake, Custom exhaust (stock turbo and exhaust manifold) bigger dump pipe, bigger injectors, fuel pump, forged internals and a tuned adaptronic ecu running 16psi. Having said that the turbo committed suicide so I'm fitting another stock one and lowering the boost until i can afford to upgrade properly.
Swile
F-Bomb 194rwkw built motor SE - Garrett, Megasquirt and Nitro Dann Power!
davekmoore
Postby davekmoore » Wed Jan 07, 2015 6:54 pm
Anyone else getting 16psi and 170rwkw from an SE with a IHI turbo?
davekmoore
Postby davekmoore » Wed Jan 07, 2015 8:19 pm
and since E85 not mentioned, assume this is with 98 octane?
Roadrunner
coyotes after you
Postby Roadrunner » Thu Jan 08, 2015 1:48 pm
I think you'll find Swile "was" running 16psi (and I know it was, iv been in the car with him!)
However 16psi wasn't too good for the turbo and as such imploded on itself (or as said, it committed suicide lol)
MeepMeep
davekmoore
Postby davekmoore » Thu Jan 08, 2015 7:15 pm
Hence my specific question.
Roadrunner
coyotes after you
Postby Roadrunner » Thu Jan 08, 2015 9:12 pm
Ahh gotcha :wink:
MeepMeep
The American
Postby The American » Fri Jan 09, 2015 8:43 am
NB Vvt
8.5:1 Pistons + rods
Head port & polish
ID1000s
HKS FPR
GT2860 + intercooler
Haltech + EBC
E85
14.5 PSI
191 RWKW on hub dyno (Mx5+/GT AutoGarage)
