NB Throttle Cable Bracket wanted.
Aiming Faster
Postby Aiming Faster » Thu Nov 26, 2020 12:57 am
Hi All, I'm needing a Throttle Cable Bracket for an NB8B, it's the one closest to the Throttle Body.
Also chasing 3 Fuel Rail spacers (black) if anyone has any of these...
Appreciate your help!
greenMachine
Re: NB Throttle Cable Bracket wanted.
Postby greenMachine » Thu Nov 26, 2020 11:11 am
Are you asking about the spacers/brackets under the car, that also carry the brake line? I have some of those, and the bracket on the plenum - just have to find them, if you are still looking.
:mrgreen:
Aiming Faster
Postby Aiming Faster » Fri Nov 27, 2020 2:38 am
I'm chasing the three spacers which hold the fuel rail to the head. They're round, stepped, insulating and black.
The Throttle Cable Bracket has two 6mm bolt holes, L shaped and is what you adjust the cable freeplay on.
I'm reverting back to stock intake plenum etc, from running Jenvey ITBs, which will be available for sale soon.
GR124
Vehicle: MX5 Locost
Postby GR124 » Fri Nov 27, 2020 9:20 am
If you get stuck let me know. I do have a spare set of fuel rail spacers I was going to keep.
I can part with a bracket.
greenMachine
Postby greenMachine » Fri Nov 27, 2020 4:54 pm
I should have those spacers, just like I should have the bracket, but so far not anywhere that I have looked :(
GR may be your best bet, if if not sourced elsewhere already.
:mrgreen:
Aiming Faster
Postby Aiming Faster » Tue Feb 16, 2021 1:45 am
Bump up.
I was given 2 of the 3 Fuel Rail Spacers, so now after 1 more only, and the Throttle Cable (Plenum) bracket - if you can help out...
