Hi,
I'm running into so problem today with my NA today.
I was fixing up the exhaust manifold and than i realise there was some coolant coming out of one of the pipe if i pull it backwards.
The pipe is under the exhaust manifold please look at the picture below its the one with red circle.
When i pull the pipe back its leaker at the blue arrow.
Just wondering if this is normal??
THanks
Coolant Pipe near Exhaust Manifold, Possible Leak NA MX5
Re: Coolant Pipe near Exhaust Manifold, Possible Leak NA MX5
ZL,
There is an O ring on the pipe that seals the pipe to the alloy housing.
Drain coolant, remove nut from manifold, remove pipe and go down to your local bearing place and get correct O ring, refit, refill enjoy
It's a common fault on these engines, both in MX5s and 323s/Lasers/Astinas. It's called a heater bypass pipe or a water bypass pipe.
Remove the pipe - it just pulls out of the water pump body at the front. Check the full length of the pipe for rust and damage, especially around where the o-ring seals at the front. If it's rusted or if there's not a good smooth surface all around where the o-ring goes then replace the pipe (wreckers or Mazda or http://www.mx5parts.co.uk/water-bypass-pipe-p-991.html ). Always replace the o-ring (50c from Repco) and clean out the entry into the back of the water pipe with steel wool.
manga_blue wrote:It's a common fault on these engines, both in MX5s and 323s/Lasers/Astinas. It's called a heater bypass pipe or a water bypass pipe.
Hi, thanks for the reply.
I haven't completely removed the pipe yet just that when i pull it back a bit it leaks little coolant. Is this how the pipe and pump is designed?
In this circumstance will i need to replace the O ring, if i replace the O ring will i need to replace the coolant as well?
Thanks
Yes it's normal.
As long as it doesn't leak when sitting in place bolted on exhaust stud. Wouldn't hurt to replace the o ring though as others have said
You'll lose a lot of coolant when you pull the pipe out. Might as well flush it all out, check and replace any old hoses and replace the coolant then. Have a good look at all the little hoses that run between the back of the head, the oil filter mount, the throttle body, etc at the same time. They're really common failure points and people to get to, especially at night on a back road. You can replace those ones with stock 1/4" water hoses from Repco.
- Learner Driver
Heres a How-To video I put together today showing how to fix this issue....
