Nb series diff strength
Pocoed
Postby Pocoed » Mon Aug 08, 2016 11:39 pm
Hi all,
Hoping someone on here has experience with testing the strength of the nb8b 7 inch diffs? Looking for information regarding either the non lsd 3.63 or the 3.9 Torsen limits. Any idea on maximum torque ratings??
Thanks in advance
beavis
Re: Nb series diff strength
Postby beavis » Tue Aug 09, 2016 12:02 am
Over 350nms I think... don't run slicks and you should be safe.
Usually a gearbox will fail before a diff.
Pocoed
Postby Pocoed » Thu Aug 11, 2016 11:24 am
Thanks for the reply. Do do you have think a car with 350nm with a different box would be then ok for street use but right on the limit? Would the diff, hubs or driveshafts be the next weakest link?
greenMachine
Postby greenMachine » Thu Aug 11, 2016 3:03 pm
Is this a question based on a real car, or ... ?
Gearboxes are THE weak link. There is no easy/quick/cheap/good fix. Live with it, or go find something else to modify.
:mrgreen:
PS Try google. There is a cubic shedload of information out there on this issue, not so much on this site.
smy0003
Postby smy0003 » Thu Aug 11, 2016 4:27 pm
Hopefully Pocoed won't mind me speaking for him, but he was talking about an engine and box swap the other day, and was wondering whether the rear subframe and diff needed to be swapped as well.
Maybe Dann will chime in, he has tuned 5's with forged engines and lots of torque.
[b]Then: Sunlight Silver NB8B
Now: Chaste White NA8
Pocoed
Postby Pocoed » Mon Aug 15, 2016 10:46 pm
Thanks smy0003, am looking at a v6 conversion and am not sure whether I would be pushing my luck keeping the factory diff and driveshafts
speed
Postby speed » Tue Aug 16, 2016 6:54 pm
Just curious.. what V6?
I love a good engine conversion :)
Postby NitroDann » Tue Aug 16, 2016 7:16 pm
LFX V6.
230 Ft Lb,
Less than many stock engine turbo builds, the diff and shafts will be fine no problem at all, however a 5 speed wouldnt. Youd wat to keep the LFX box or a 6 speed.
That simple,
speed
Postby speed » Wed Aug 17, 2016 6:33 pm
Interesting. I'd like to see it happen. Good luck with the build :)
