Guarantee void if removed tag on head?
jp928
Postby jp928 » Fri May 13, 2016 11:47 am
Recently bought an almost complete engine - NA8, 94-95 I think, off ebay. Plan is to build a replacement for current poor oil pressure unit. Possibly a grey import unit.
Just noticed an oddity on the back of the head (BP05) - round ally disc ~12mm dia, with a bit of grey non-hardening gasket around it, with the words 'Guarantee Void if removed' around the edge.
Anybody ever seen anything like this before?
jp 92 NA6, 96 na8 in a clubbie with turbo.
Re: Guarantee void if removed tag on head?
Postby NitroDann » Fri May 13, 2016 12:29 pm
It lets the reconditioner know if the engine overheated.
jp928
Postby jp928 » Fri May 13, 2016 1:10 pm
Ok, good. What changes if it has overheated?
jp
Postby NitroDann » Fri May 13, 2016 1:18 pm
Colour I think. Maybe the glue fails a X degrees, not sure. But that's what its for.
sailaholic
Postby sailaholic » Sun May 15, 2016 6:50 pm
Side note is your low oil pressure unit based of the stock gauge. They are notoriously inaccurate.
pie5
Postby pie5 » Sun May 15, 2016 11:48 pm
It's called a heat tab. The center will melt if the head gets too hot. In case there is a failure of the head. Lots of engine reconditioners use them.
2019 Racing Orange 30AE #783
2006 Stormy Blue NC 2.4 GWR Header & Exhaust, Progress Springs, Koni Shocks, Whiteline Sways, Recaros.
