lightyear happens to know where there's a V6.
If you're going to go turbo, just give NitroDann enough money and enough time to work on your car.
If you don't follow that advice, follow this:
Get one person or one shop to do all the work and take responsibility for it.
185kw turbo built na6 engine -what do I need?
- davekmoore
Re: 185kw turbo built na6 engine -what do I need?
Re: RE: Re: 185kw turbo built na6 engine -what do I need?
davekmoore wrote:lightyear happens to know where there's a V6.
Thanks Dave.
Already have the turbo bits and will be using the machinist I always use.
The engine will be built either by myself or a good friend.
Also have a local engineer and tuner lined up.
There is no time frame, just when I can.
Appreciate your advice.
