Engine fires then dies
Nevyn72
Re: Engine fires then dies
Postby Nevyn72 » Sun Feb 14, 2016 6:20 pm
speed wrote:
davekmoore wrote:Where was the little hose that was leaking?
Was there no smell or visible petrol?
He said it just off the fuel pump. So out side tank. Was a small split which if you think about it, would drop fuel pressure, hence why the motor would cut out with any throttle ;)
Not necessarily, if the pump has been replaced previously there is a small amount of hose used to connect the new pump motor inside the fuel tank.
See this image. :wink:
Coote_00
Postby Coote_00 » Sun Feb 14, 2016 7:02 pm
Hey guys yes That's exactly what's happened had a split in hose was getting fuel to the rail but when I put my thumb over it it stopped the flow.
speed
Postby speed » Sun Feb 14, 2016 11:10 pm
Coote_00 wrote:Hey guys yes That's exactly what's happened had a split in hose was getting fuel to the rail but when I put my thumb over it it stopped the flow.
Coote, was the split hose inside the tank or outside? Just may help others knowing the exact location.
Thanking you.
Coote_00
Postby Coote_00 » Mon Feb 15, 2016 11:21 am
Hey guys it was the little one inside the tank
speed
Postby speed » Tue Feb 16, 2016 8:21 am
Coote_00 wrote:Hey guys it was the little one inside the tank
Thanks for that. Seems like Dave and Pete were on the money. I also learned a valuable lesson, so thanks again!
