NA 1.8 Header Removal - Any Tips?
gslender
Re: NA 1.8 Header Removal - Any Tips?
Postby gslender » Sat Aug 23, 2014 3:15 pm
I used to own a set of 12pt sockets, and would (on occasion) round a nut. Paid a little more and bought a set of Metrinch sockets that grab the sides, not the points and have never had a problem since. With a little heat (from a torch for about $20) and if you first tighten before you loosen, almost anything will come off. Another trick is to have someone strike the head of the nut with a hammer whilst you loosen with the spanner - the shock will allow the nut to crack.
Purfler
Postby Purfler » Sat Aug 23, 2014 7:50 pm
1993 NA LE. 1968 Datsun 2000 Sports (SR311U) - in bits. Disclaimer: In this as in most other thing I have absolutely no idea what I'm talking about.
