Fitted SuperPro Void fillers to the back of the NB8A because they were cheap and I was bored.
P/N SPF2875K
Took 15 minutes
Tools
12 mm socket
17mm socket
200mm extention
Wiss Snips
Safety first, jack up car, chock front wheels and place on stands, place jack under diff housing and take up the slack.
Remove these >
Lower jack enough to have access to top section of mounting bolts (about 50mm) >
Cut rings and fit to top section of mounting bolt, little bit fiddley but by no means hard >
Jack the diff back up to take up slack, place lower section on and do bolts back up >
Profit
Fitted diff bush void fillers
Re: Fitted diff bush void fillers
Removed bottom void bushings due to major NVH.
