well a 205/50/15 is going to be better on the track in terms of grip (assuming comparable tire types). Plenty also run 225/50/15 race rubber.
195's are cheaper though and will give you the gearing change.
Do I have an LSD? and diff gear question?
Re: Do I have an LSD? and diff gear question?
emily_mx5 wrote:OP be aware that 99% of this forum is happy with nothing but 15" NB8A/6UL/RPF1 wheels regardless of what MX5 you have lol.
I only use 15s because they're cheaper. Cheaper to buy, and cheaper to get tyres.
OP, standard sizing for a 99 MX5 is 195/50/15, which is a total rolling diameter of 576mm
If you've got something larger than that (rolling) it will have the effect of slightly taller gearing. (and I mean slightly)
Alos bear in mind that some states have rules about rolling diameter, in Vic it was (I think still is, but I haven't checked lately) that you could increase rolling diameter by up to 15mm I think.
- Guran
- Vehicle: ND - 1.5
sailaholic wrote:A Torsen will not do the opposite spin thing. They are based on a torque bias not a speed bias. So when both wheel are in the air they act like an open diff.
You're correct! I recently bought a 10AE (standard Torsen LSD) and just tried this test. With both rear wheels raised, turning one wheel causes the other to slowly rotate in the opposite direction (at reduced speed).
- Dweezle
Bryan are you buying one of each ???
ALL MUSCLE CARS ARE CRAP
Jeremy Clarkson
Jeremy Clarkson
Guran wrote:hks_kansei wrote:NB8A 10th Anniversary - 3.? - Torsen T2
In Australia, the 10AE had 3.636:1 final drive ratio (Torsen) in place of the 4.10:1 (open) used with five-speeds. The 10AE had 3.909:1 diff ratio (Torsen) in other markets.
Reference
Here's the Mazda Australia Specification Sheet (along with Equipment Sheet) that also confirms 3.6 FD:
viewtopic.php?f=78&t=45043
- Guran
- Vehicle: ND - 1.5
Dweezle wrote:Bryan are you buying one of each ???
Not permanently but yes, at present I have a full set NA, NB, NC.
- Aussie Stig
- Stig
Guran wrote:Dweezle wrote:Bryan are you buying one of each ???
Which is 'best' ?
Oh no.
- Aussie Stig
- Stig
sailaholic wrote:Oh no.
Users browsing this forum: No registered users and 87 guests
