The new 'sealant' on the TB butterfly has helped a bit, starts a lot smoother and easier now, seems to run smoother too. Thought it may have fixed the issues driving to work happily and enjoying the car then I pull into work and it plays up in that rough spot again, same on the way home, Happily driving along enjoying some roundabouts got pretty much home without an issue then it plays up again jerking back and forth. I so wish I had another car to drive, Im not liking driving the mx5 at the moment
Unless the base idle has always been set with no sealant on the butterfly, maybe now that's fixed the base idle needs to be set again and hopefully its all resolved and stays that way.
