I took the 5 in for a new muffler today, and once it was up on the hoist we discovered quite a bad coolant leak. It appeared to be coming from the water pump area. The water pump is only 20,000 k's old, but I'm suspecting the gasket due to something a bit dodgey I did that I won't go into right now.
So once the new muff was fitted I topped the radiator up while watching it leak out under the water pump. I only had a ten min drive home so I took it easy, but temp was not rising above normal so I accelerated to highway speed and got home no worries. Here's where it gets weird. I pulled up in my garage expecting to see coolant leaking everywhere, but nothing. So I let it cool down & took the cap off the radiator only to find it full. Go figure??
I'm going to put a new water pump gasket on anyway, as well as checking all hoses etc. But why would the leak fix itself?
I'd be grateful for any ideas.
Andrew.
