The NA8 had a blue plug behind the left headlight area with a constant 12 volt power source. NA6 the same?
If it's getting spark and fuel then it's starting to look like a broken cam belt or timing completely out of whack.
car wont start! please help!!!!!
- JBT
Re: car wont start! please help!!!!!
JBT wrote:The NA8 had a blue plug behind the left headlight area with a constant 12 volt power source. NA6 the same?
This is the one I was talking about. It's not constant power. Power is cut to this circuit during cranking.
- Caffeine
From memory there's a B+ pin in the diagnostic port that's a straight feed from the battery
I haven't fitted a CAS to an NA6 for a long time. Does anyone know if it's at all possible to get the CAS 180 deg out when sliding it onto the end of the cam?
- aka_juffa
I don't think it can be fitted 180 degree out. I think it can only go on one way.
- mxfive95
I had this problem when I swapped engines a few years back. On an NA8, its posible to install the cas 150deg out if you put it in upside down :/ . Take a photo of the cas sensor and post it up.
The bumper sticker on my porsche
"My other car is an mx5"
- Vehicle: NA6 - Supercharged
have you checked the air intake for blockages .. cars need spark, fuel, air, and compression to run
Supercharged NA6
- tescoking
Idle air control too old or dirty? It happened to me before, and I bought a second hand one on ebay and now is working fine
