My mx5 keeps stalling?
angusis2fast4u
Postby angusis2fast4u » Sat Jul 06, 2013 10:47 am
Hi i have a 1990 Eunos Roadster and every so often it will stall, i have never caught it stall when just idling but i've noticed it the most when i am slowing down (clutch in or in neutral) or have just stopped, i think it only happens once it has warmed up but it could have happened once before it reached running temp. what should i do?
~Angus
2001 Silver NB8B
Past: Grey 1990 Eunos Roadster
Re: My mx5 keeps stalling?
Postby 93_Clubman » Sat Jul 06, 2013 11:30 am
angusis2fast4u
Postby angusis2fast4u » Sat Jul 06, 2013 8:27 pm
93_Clubman wrote:This might help: NA6 Idle Dip:
http://www.miata.net/garage/KnowYourCar/S7_Idle.html
It's not a dip in the idle as such and i don't notice this dip at all, it's either fine or stalls it has 150,000 and 3 previous owners and since it never goes below 800~ im guessing this may have been addressed as an issue already?
~Angus
2001 Silver NB8B
emily_mx5
Postby emily_mx5 » Sat Jul 06, 2013 9:25 pm
93_Clubman is right, try re-seting the base idle.
Also, grab a can of carby cleaner and clean your throttle body, cold start valve, isc valve, and if you can be bothered the whole intake manifold.
angusis2fast4u
Postby angusis2fast4u » Sat Jul 06, 2013 9:35 pm
emily_mx5 wrote:93_Clubman is right, try re-seting the base idle.
Okay thanks, I have later had a deeper look into google and found out this isn't a too uncommon problem, it had it's service not 2 days ago and im not sure if it did or did not do this before the service but ill open the whole intake and have a good clean of it
~Angus
2001 Silver NB8B
Postby 93_Clubman » Sun Jul 07, 2013 12:02 pm
angusis2fast4u wrote:it had it's service not 2 days ago and im not sure if it did or did not do this before the service
It's great that you've just had the car serviced immediately after buying it. NA6s are 20 or more years old now, & servicing sometimes gets overlooked after the purchase & the big spend it involves. Some have full service histories, & that's great, but some don't even have recent service histories. So for a 20 or more year old car it can be useful to baseline (full) service it so that you have a known starting point if you later have to diagnose an issue. Of course, additional benefits are sorting existing issues & improving reliability.
slimx
Postby slimx » Sun Jul 21, 2013 3:15 am
If you get the chance and have the ability, good to run a quick code check too. See what's coming up as an error etc.
A check up never hurts. Get the problem before it gets you in the middle of the road!
