Engine gauge display. Etb digi dash
mazmad
Postby mazmad » Mon Apr 15, 2013 8:45 am
Anyone used one of these? ETB DigiDash 2 Lite Digital Dash Display Black
The Digidash 2 LITE Digital Display System replaces all dashboard instruments in one compact, lightweight, anodised aluminium display module. DD2 systems include all sensors and display the following parameters: Speed, RPM, Water Temperature, Oil Pressure, Oil Temperature, Volts, Fuel level and Engaged Gear.
Designed to be SVA compliant the DigiDash 2 Lite is road legal and compatible with all negative earth ignition and diesel applications.
Standard Feature include :
Programmable shift-lights with 2 selectable modes of operation.
Road Legal odometer, trip distance counter and trip-meter.
Engine Hour counter.
Acceleration/deceleration timers (e.g. 0-60).
5 programmable warning alarms.
5 key road legal dashboard warning lights.
1 configurable AUX warning light (e.g. Neutral for bike engined cars).
Configurable speed calibration to suit any vehicle.
Programmable speed warning.
MPH or Km/h selectable
User selectable display units (Celsius or Fahrenheit, PSI or BAR).
Peak value memory on all parameters.
Adjustable brightness and contrast.
Compatible with all negative earth ignition systems.
Front side fully sealed against dust and water ingress to IP67.
Designed to pass SVA regulations and requirements
Speed, water temp, oil temp, oil pressure and fuel level sensors included.
Supplied with wiring harnesses and DigiTools software on CD ROM.
12 month warranty
Also included in the features of The DigiDash 2 Lite is a recording facility which stores the last 10 minutes of data from a choice of 4 channels - Speed, RPM, Distance and Oil pressure. This data can then be downloaded to a PC or laptop using the supplied DigiTools software. This is extremely useful for checking oil pressure readings, identifying oil surge, confirming corner speeds and tailoring gear ratios.
http://www.demon-tweeks.co.uk/motorsport/dash-displays/etb-digidash-2-lite-digital-dash-display
