Over time I have had some temperamental shuddering coming from my rear passenger wheel. It seems to only occur in reverse and sometimes in first gear. After doing some research, I have reason to believe it is a bad U-Joint. My car is a 1990 NA6.
How would I go about making sure that it is in fact the U-Joint and what would be the best way to replace it? I read that the driveshaft and U-Joint are one unit? I think that's only for the NA8+ but someone said it was the case for the NA6 as well.
Bad U-Joint?
- de Bounce
Re: Bad U-Joint?
MX5 drive shaft rarely give trouble.
The rear brake calipers are known to seize, specially on the NA's
A sticking caliper could produce the shudder.
Have you checked they are releasing and moving correctly!
Re: Bad U-Joint?
I had a rear caliper seizing on my NA - a real basic quick way to check is put your hand on the rim and check the temperature - my rim got rather warm compared to the others.. (and a bit stinky..)
Re: Bad U-Joint?
Another consideration given it occurs in reverse, & occasionally first gear, is a loose PPF bolt or a crack in the PPF:
viewtopic.php?f=29&t=40896
viewtopic.php?f=29&t=42534
