Hoping someone can answer this.
Is the bolt pattern on the Duratec and B series (BP) bellhousing-block pattern the same?
Eg: does a duratec bolt to a BP gearbox?
Woz
BP - Duratec bellhousing pattern
- wozzah1975
Re: BP - Duratec bellhousing pattern
Is the duratec the same engine as the mazda mzr?
- mrpham
Don't know if it's the same bolt pattern, but I know that the starter motor is on the opposite side.
Current Forum Specials!
- wozzah1975
mrpham wrote:Don't know if it's the same bolt pattern, but I know that the starter motor is on the opposite side.
Any of the hang on's don't matter, as long as it bolts up
Woz
- 16bit
if you figure out how to do a duratech swap i may just pay you to do it to mine!!!!!!
- mx5racing
- Vehicle: ND - 2
No they dont fit.
- wozzah1975
mx5racing wrote:No they dont fit.
Thank you,
Woz
