Hi All,
Just joined the forums here - and just bought an MX-5 last week.
I bought a 2006 NC from a dealer in Sydney. When buying, I noticed a noise behind the passenger seat, even when the car was not in motion. It sounds like a somewhat high pitched whine - near where I would think the fuel pump is.
I pointed this out to the dealer, and they committed (in the purchase contract) to rectify it. They're now trying to tell me that it's normal - and I'm trying to get some advice here. Is fuel pump noise normal?
I'm 100% sure this isn't body/wind noise. I've checked it inside when not moving. It clearly sounds electrical/flow related. It is similar to the noise you hear behind the passenger seat when you switch the car to accessory mode - which sounds like the fuel pump spooling up. It stops in that case, but with the engine running, it is constant.
Any advice?
Thanks,
Cemil
Fuel Pump Noise?
- Learner Driver
- JBT
Re: Fuel Pump Noise?
It is not normal. Hold them to the contract - if they agreed at the time of signing that it needed to be rectified, then it still does and they have committed to fix it.
- Learner Driver
JBT,
Thanks - I'm guessing it's flow noise, but I will definitely hold them to it.
-Cemil
-Cemil
Mine's a 2006...absolutely no noise from the rear when not moving
Rob
- Learner Driver
Hi Sailor,
Thanks for the feedback - it's tough to notice if there's ambient noise (top down especially), but at night, on a quiet street, it's definitely noticeable.
-Cemil
-Cemil
