blue top 1.6 injector question?
does anyone know what cc the factory 1.6 injectors are? i've been searching all afternoon for a definitive answer but ive seen them listed as 205, 215 and 230!!! i need to put the number into the emanage software so it can calculate the change now that i've installed 2jzge supra injectors.
Re: blue top 1.6 injector question?
Fuel Injector Blue 195500-1970 13.8 Ohms 212cc
- Vehicle: Non MX-5
http://miataturbo.wikidot.com/fuel-injectors
Are rated at 3bar 42psi pressure. Some setups like the early BPTs use 38.5psi, as sometimes the injectors are rated for 38.5psi. Hence you'll find slightly different capacities shown for varies injectors.
