ok to fill 6 speed via turret?
rxmx
Vehicle: NA6 - Turbo
Postby rxmx » Sat Jun 12, 2010 7:08 pm
My car has the shifter and everything out atm and I need to put new oil in the box. Is it ok to fill it via the turret instead of the fill plug on passenger side of box? I have done some searching some say yes and some say no? is this due to variations in the 6 speeds?
Thanks,
http://www.facebook.com/purefabcustom
EFR6758 run-in tune 259hp atw on 10psi pump 98 dyno dynamics
E85 tune - 445hp @ wheels 17psi
wun911
Re: ok to fill 6 speed via turret?
Postby wun911 » Sun Jun 13, 2010 1:48 am
NB8B yeah you can fill it from the turret esp if you cant get the fill plug undone.
not sure about the 10AE 6 speed...
every ounce counts
rxmx
Postby rxmx » Sun Jun 13, 2010 7:15 pm
thanks wun, i ended up filling it via turret with no dramas...
Postby NitroDann » Fri Jun 25, 2010 1:04 pm
I have filled mine through the turret twice, the fil hole is impossible to get to when you have a 6 speed in an NA.
irwin83r
Postby irwin83r » Sun Jul 25, 2010 1:13 pm
did you just put in a set amount of oil or something??
the fill hole is also the fill level
greenMachine
Postby greenMachine » Sun Jul 25, 2010 8:38 pm
irwin83r wrote:did you just put in a set amount of oil or something??
It's full when the oil starts running out .... :lol: That is not as bad as it sounds, you know how much they hold, so fast fill to close to that, more carefully as you get closer.
:mrgreen:
jerrah
Postby jerrah » Tue Jul 10, 2012 7:37 pm
My 6 speed fill plug is impossible to remove (I should have done it with the engine out a few weeks ago) - if I fill through the turret how much do I put in? 2L?
I'm glad to see I can fill through the turret!
1991 MX5
Hjt
Postby Hjt » Tue Jul 10, 2012 8:30 pm
6 speed now ay mate :D
Postby NitroDann » Tue Jul 10, 2012 8:34 pm
Whatever the manual says, you can undo it with the right sized socket, cut the socket down shorter with an angle grinder and a cutoff disk, then it will fit easy.
aviper4u
Postby aviper4u » Sat Jul 14, 2012 9:10 pm
here's a guide which i found useful
http://www.miata.net/garage/6mt_fluid/index.html
