Transmission Removal Issues
toddl1
Postby toddl1 » Sat Feb 18, 2012 5:33 pm
I have an '89 Eunos NA with the stock 1.6L engine.
I'm trying to remove the transmission for a clutch replacement, I have removed all the bolts around the bell housing except the bottom two which attach the starter to the bell housing. this is because they are rounded off, and unremovable. I have undone the bolt which attaches the starter to the engine bolt, and as far as I can see there is nothing else attaching the starter to the engine, so I reckon the starter should come off with the transmission. Except I can't get the transmission off, it's seperated from the engine by about 1cm all around and I can see the teeth on the flywheel but it won't move any further. I've tugged, twisted and smacked it as much as I can but it won't budge.
Should I just continue to use force? or is there something else attaching it to the engine?
1989 Eunos Roadster
Zcootz
Postby Zcootz » Sat Feb 18, 2012 5:43 pm
Lesson learnt from bitter experience, don't continue using force. Something will break.
With two laps to go then the action will begin, unless this is the action, which it is.
Murray Walker
Russellb
RIP Nov 2014
Re: Transmission Removal Issues
Postby Russellb » Sat Feb 18, 2012 7:22 pm
There is a cover plate between the engine and the G/Box that is held to the engine block by 1 6mm (10mm head) bolt.
YOU HAVE TO UNDO THE STARTER to get the G/Box out
If the head of the bolt are rounded then try HAMMERING on the next size down socket to undo
My ClubmanRebuild
MX5 SE Rally car is HERE :)
Postby Mr Morlock » Sun Feb 19, 2012 10:44 am
having a repair manual is a big help- or access to the pages on clutch removal and refit. Russel probably solved it for removal. You probably need to address the damaged bolts.. [
toddl1
Postby toddl1 » Sun Feb 19, 2012 10:36 pm
cheers for your help, I'll try and get the starter off tomorrow.
1989 Eunos Roadster
deviant
Postby deviant » Sun Feb 19, 2012 10:58 pm
Dont leave the gearbox hanging on the input shaft.
toddl1
Postby toddl1 » Mon Feb 20, 2012 8:19 pm
yeah it's all good now new clutch is in.
Another thing, where can I get replacement bolts for the bellhousing, are they only available Mazda Genuine?
1989 Eunos Roadster
taminga16
Postby taminga16 » Mon Feb 20, 2012 8:25 pm
toddl1 wrote:yeah it's all good now new clutch is in.
Take a sample to a nut and bolt bloke or industrial supplies.
Greg.
