Interested in value as well as performance increase and overall happiness with the product?
Just want to get as many opinions as i can before making my decisions,
Matt
matt2424 wrote:Just wondering if people had suggestions for intakes and exhaust set ups for an 05 NC?
Matt
Charlie Brown wrote:Best bang for your buck is without doubt a set of headers. And yes dyno’s are not the be all and end all but my car registered 91.6rwkW standard and 105rwkW with the headers. Cost is about $555 landed, snail mail from Goodwin Racing. http://www.good-win-racing.com/Mazda-Pe ... haust.html
Cold air intakes for the NC, in my opinion, are a waste of money. The standard intake sits horizontally in the nose of the NC and takes in cold air without modification.
I have a Cobalt CAI fitted, cost was about $140 delivered including filter when I got mine it’s slightly dearer now. http://www.miatamania.com/Shop/ViewProd ... exID=73664
The Cobalt CAI is the same length as the stock intake but sits vertically with the intake behind the lower slot in the nose. The K& N panel filter has the advantage that you can wash it clean, which you do often as the CAI picks up sand and bugs easily.
I noticed no difference when I fitted the CAI and there is no additional intake noise. The AEM / Mazdaspeed (about $360 landed, snail mail from Goodwin Racing) sits diagonally across the nose, its longer than standard and may have a minimal increase in torque at lower revs. Chris has dynoed a number of different CAI’s on his race NC’s and only picked up 1kW.
Mufflers. A word of warning. If you fit headers there is only one muffler to get and that’s the Goodwin ‘Q’ (cost $836). Any other will be way too loud. I’ve tried 5zigen, and the Roadstersport with baffles in and both will have you defected and your neighbours chasing you down the street trying to do you some injury.
Also besides the overwhelming loud note you have drone which kills the pleasure of driving even with a loud exhaust note. I think the note the stock muffler gives with the headers is fine, the main reason I wanted to change was a decrease in weight which would eliminate me having to swap mufflers at the track.
Performance wise Goodwin has some figures on his site about the development of the mufflers which is a good read. If you believe the figures you look at about a 4rwkW gain. A new mid pipe (cost $643) around another 2 rwkW.
So summarising a set of headers for $555 will get you around 13rwkW.
Add an AEM intake, a mid pipe and a Q muffler for $1839 and you get another 7rwkW. Pretty easy to see where you need to spend your money.
Gmi wrote:AEM cold air intake is best bang for buck if you buy intake. But goes all the way down... So as a daily driver in my opinion wouldn't be suitable.
I have the Hks one. You will need to build a heat shield yourself, similar to LAILE. The Hks sounds good and dresses up your engine bay, also better throttle feel. Hp gain I gave no clue, probably close to nothing.
Roadstersport from goodwin; good value definitely. But if you have a big budget other options are:
HKS full system
RE amemiya full system
Both looking at more than 3500AUD. But you will add jdm points :p
Black_Penguin wrote:Bigger chance of sucking up water/mud/gravel. Mud and gravel will clog up the filter and reduce flow and water doesn't compress to well.
