Piston Rings for 6B in NA (turbo listing)
lukearama
Postby lukearama » Mon Feb 14, 2011 5:04 pm
Just completing a re-ring freshen up of the NA 6. My parts guy ordered in the rings for the 1.6 but when went to install they were smaller the ones removed. Further study showed that the listing Hasting had listed the rings for my model under the Turbo engine fitment. The oil control ring is 1mm larger. not sure of other differences???
Can anyone shed some light on this????
Apart from Mazda............ trust nothing else...
tbro
Re: Piston Rings for 6B in NA (turbo listing)
Postby tbro » Mon Feb 14, 2011 6:46 pm
lukearama wrote:Just completing a re-ring freshen up of the NA 6. My parts guy ordered in the rings for the 1.6 but when went to install they were smaller the ones removed. Further study showed that the listing Hasting had listed the rings for my model under the Turbo engine fitment. The oil control ring is 1mm larger. not sure of other differences???
The rings sets are to 1991 3mm oil control rings and after that 4mm control rings, some list as auto only with 4mm rings????????
Trouble is, thats what the parts list say, but what you have in your motor is only known after you measure your old ones.
Trust me its a PIA. Below is the ACL parts list
LEGEND PISTON KIT - MKRY (contains Premium rings) - Moly or Chrome), KRY (contains Plain rings)
RING SET - M (Moly), C (Chrome), PS (Plain)
LOCKING DEVICE - AC (usually press fit), CC (wire circlip), SC (seager circlip)
NOTES
BEFORE ORDERING PLEASE CHECK WITH YOUR LOCAL DISTRIBUTOR FOR AVAILABILITY OF OVERSIZES 113
1597cc 1597cc 1597cc
323 323 MX-5 MX-5; 323
B6 SOHC 8 Valve B6 SOHC 16 Valve B6 DOHC 16 Valve
1985-90 4 1989-on 4 1985-on 4
78.000 83.600 78.000 83.600 78.000 83.600
3.0708 3.2913 3.0708 3.2913 3.0708 3.2913
64 202 212
4KRY8041(1) 4MKRY8042(2) 4KRY8044
STD/0.50/1.00 STD/0.50/1.00 STD/0.50/1.00
4MKRY8041(1) 4MKRY8044
.0200 @ 46.70 .0200 @ 47.30 .0200 @ 47.30
31.40 20.000 32.00 20.000 32.00 20.000
AC AC CC
1.500 1.500 3.000 1.500 1.500 3.000 1.500 1.500 3.000
3062B 3062B
M1729(1) M1821 M1729(3)
1.500 1.500 4.000 1.500 1.500 3.000 1.500 1.500 4.000
M1821(1) C1821 M1821(3)
PS1729(1) PS1821 C1821(3)
STD/0.50/0.75/1.00 STD/0.50/1.00 STD/0.50/1.00
1.500 1.500 4.000 1.500 1.500 3.000 1.500 1.500 3.000
PS1821(1) PS1821(3)
(1) 4KRY/4MKRY8041 supersedes 4KRY/4MKRY2842 (3) M/PS1729 ring set suits some original models
upon consumption of all 2842 pistons. with 1.5,1.5,4.0mm rings.
M/PS1821 ring sets suit 8044 piston.
New 8041 piston uses M/PS1821 ring set with
1.5, 1.5, 3.0mm rings.
Old 2842 piston uses M/PS1729 ring set with
1.5, 1.5, 4.0mm rings.
(2) 4KRY/4MKRY8042 supersedes 4KRY/4MKRY2902
lukearama
Postby lukearama » Mon Feb 14, 2011 9:17 pm
Wow... many thanks Cyclops. Thats certainly shed a Hella Rally 4000 on the subject. Cheers
Postby manga_blue » Tue Feb 15, 2011 10:47 am
