NB8B timming belt change...
- bigdog
- King of the kennel
Re: NB8B timming belt change...
Sorry - brain not working. Same for non VVT cams, different with. You've got it sorted though so all good. STM has a pic on here somewhere that clearly shows the timing marks and tooth count on the belt you should be able to find it with a search.
- aviper4u
Hey peeps,
Put belt on following mike's place vid clip looks good from what i can see though if you guys aren't too hungover would love a second opinion
Uploaded with ImageShack.us
thanks to everyone's input
hopefully ill be cruising soon!!
That looks good I see you got the cam seals in because its blue...
every ounce counts
- aviper4u
thanks hopefully is all good.
also when tightening the crank bolt did u use special or put in 6th gear with handbrake up? as having trouble with my tool...
anyways wanna finish today but after yesterday and today's hot weather might wait it out till tomorrow
- aviper4u
car started and runs fine
though when filling radiator and leaving cap open water was overflowing from the cap and was not being sucked through and bubbling like what should happen?
what gives ?????????
any help appreciated
Users browsing this forum: Google [Bot] and 10 guests
