My SE has quite a while to go before I need to replace its belts. I've done a couple of alternator belt changes in my previous NA, and compared to the very crowded extra plumbings and various doodahs in the SE, the NA job is almost like a walk in the park. I remember there is a bolt at the bottom of the alternator which I could access from the front and lock the nut at the back with either a box or open ended spanner lock. I know it's very cramp IN the NA but it can be done if you remove the charcoal cannister.
I have taken several hard look at the SE alternator and am wondering how the hell can one change its belt? Do I need to loosen the bottom bolt which is not visible in the attached pic and undo the three visible bolts at the top, and if I need to loosen the bottom bolt, how can I access that rear locking nut? Do I need to remove the undertray to access from the bottom? Wouldn't the steering rod and other plumbings get in the way? Please enlighten me.
