Crank timing issues - aka the "short nose crank problem"
Alf
Postby Alf » Tue May 18, 2010 11:32 pm
Well, my car's been in the shop for a week now. Sent the service manager a link to NMX-516's original post on day 1. Today he rings me up very embarassed that they've tried everything then called in the Mazda Aus techs, and now have decided that it's the issue I pointed them at in the first place. Said "We're ordering a new pulley and timing belt".
"hmmmm...." I replied "Better actually check the crank keyway, you may need to order more than that"
Grrrr...
Lucky my young bloke's off the road with an accumulation of points ATM, and we have a spare car in the driveway.
Alf
Wuey
Postby Wuey » Wed May 19, 2010 1:41 pm
Well I know nobody else other than myself will be doing my timing belt replacement. Having done my previous NA, I reckon I can handle this job on a nice Sunday arvo.
Image 2004 SE
Postby bruce » Wed May 19, 2010 2:25 pm
Geebus, sorry to hear that. May as well skip the 100K service and take the risk of the belt busting, as compared to the risk of a poor reinstallation.
greenMachine
Postby greenMachine » Wed May 19, 2010 9:15 pm
bruce wrote: May as well skip the 100K service and take the risk of the belt busting ....
:shock: :shock:
It it not a risk, it is a certainty. Only question is when, where you are at the time, and just how inconvenient and expensive it will be to get it fixed. At least the (standard) engines are not interference like some others, so it will not be a full engine rebuild.
This is one of the silliest statements I have seen in a long time :roll:
:mrgreen:
Postby bruce » Fri May 21, 2010 10:45 am
I was only kidding.
But, compare it to the cost of a new crank. Even Mazda can't seem to do a belt change correctly.
samx5
Postby samx5 » Fri May 21, 2010 5:05 pm
Does anyone know the Mazda part number for the crank pulley bolt (NB8A)? My timng belt was (apparently) replaced by the dealer shortly before I bought my car in December, so they should have a record of the parts they used, I would like to check that the bolt was replaced at that time. Cheers
Was: 1988 Corolla 4A-GE Twin Cam, 1991 Laser TX3, 1995 Peugeot 306 S16, 2003 Astra Sri Turbo, 2007 SP23 Lux
Now:1999 NB8A, 2011 Outlander VR-X
Postby 93_Clubman » Sat May 22, 2010 1:58 am
samx5 wrote:Does anyone know the Mazda part number for the crank pulley bolt (NB8A)?
should be in the following:
http://www.mazdamotorsports.com/pdfs/MX ... 0073_1.PDF
which is located on:
http://www.mazdaspeeddevelopment.com/pa ... apubs.html
