'03 is down about 6kw on '02 - not sure of exact engine dimensions & weight, but other basic specs according to Redbook are:
Engine Size (cc) 1839
Cam DOHC with VVT
Engine Number BP-######
Engine Code S-VT
Valves per Cylinder 4
Compression Ratio 10
Power 107kW @ 7000rpm
Torque 168Nm @ 5000-5000rpm
Acceleration 0-100Km/h (secs) 8.4
Recommended RON Rating 91
Fuel Delivery Multi-Point Injection
Method of Delivery Electronic Sequential
Fuel Urban (l/100km) 9.5
Fuel Extra Urban (l/100km) 6.8
Fuel Combined (l/100km) 7.8
Kerb Weight (kg) 1086
Tare Mass (kg) 1090
2003 1.8 vvt engine specs
- RawSouth
maztina wrote:What are some common mods to get a big more power out of this??
Forced Induction?
ロードスター
- Charlie Brown
93_Clubman wrote:'03 is down about 6kw on '02
An urban myth.
Numerous Club dyno days proved there was no difference in rwkW between the two engines. Mazda was forced to change it's method of testing to comply with the European emission standard.
Generally this engine is getting around 78 – 80rwkW. Add a set of extractors, and exhaust system and after market tuneable ECU and you will increase this to around 100rwkW.
Turbo it with modified internals and an ECU and you can make up to 240rwkW at which stage the gearbox starts to break. Most run them at a safe 180rwkW to ensure some long levity.
In 2002 Mazda Australia released the SP turbo which ran the stock ECU. Dyno’d standard most put out around 128rwkW. The “T” piece mod that gained another 1psi added another 10 -12 rwkW for $5.
Charlie Brown wrote:93_Clubman wrote:'03 is down about 6kw on '02
An urban myth.
More than 'urban' Charlie - there are recognised published sources still quoting 113kw V 107kw - good to hear about those dyno outcomes though.
Btw, add enlarged cold air intake to after market tuneable ECU, extractors, & exhaust system.
