high oil pressure
charlie_91
high oil pressure
Postby charlie_91 » Fri Feb 05, 2010 9:25 pm
hi, i my na6 recently over heated and now the oil pressure is higher at low revs.. eg. 3k rpm oil would be at like 6.. thats in pretty much every gear..
is this bad ? is my engine going ?
cheers
TieNN89
high oil pressure
Postby TieNN89 » Sat Feb 06, 2010 2:13 am
This is when the engine is warmed up yeah?
It could be the sender
charlie_91
high oil pressure
Postby charlie_91 » Sat Feb 06, 2010 6:03 am
yeh .. cos it'll be like htat when i first start up then just stay like that..
if its running high whats the worst that could happen ?
cheers
Juffa
high oil pressure
Postby Juffa » Sat Feb 06, 2010 2:34 pm
When you it stays like that, do you mean that the pressure guage on the dash does not move? After about 10 minutes of driving you should see the pressure drop at idle, but remain steady at higher engine revs. I would unplug the single wire from the oil pressure guage sender, clean the connection and reattach the wire. The snder is on the drivers side of the engine, just near the oil filter. A bad/dodgy connection can make the guage do funny things. Let us know if this does not change anything.
Having said that, you mentioned that the your car overheated. Have you checked to see if you have engine oil in the coolant, or coolant in the engine oil, either of which indicates that your engine head has warped due to the overheating and needs to be repaired.
J.
charlie_91
high oil pressure
Postby charlie_91 » Sat Feb 06, 2010 3:14 pm
oh sh*t..
well i think the head gasket is warped if thats what u meant by the head..
i saw it was seeping coolant and then opened the radiator cap and i saw quite a few air bubbles when it wasnt even running..
also the engine is burning excess oil as i have just found out which explains that smell in the cabin..
well looks like my na needs a new engine.. there was a small wobble in the crank pulley so it was only a matter of time..
thanks.. any other info or help would be great just to double check ..
cheers
