Injector help!!!!
Fatty
Postby Fatty » Wed Jan 10, 2007 7:33 pm
actually that's a good question, i'd tell you but my multimeter is busted.
but, from memory i think it was about 3.7 volts?? doesn't seem high enough to you? i should try and replicate your experiment using my variable power supply and see what happens.
sorry about the comment on the emanage. i didn't mean to sound like a smart ass.
what you are saying makes sense to me, it just doesn't match my results... unless i've been ripped off and gotten smaller injectors than i paid for :shock:
Shinigami!
Injector help!!!!
Postby Shinigami! » Wed Dec 16, 2009 6:16 pm
sorry to resurrect an old thread, but i'm looking into some injectors for my na6 miata. presuming that people have put gtr injectors in would i be right to presume that i can use ca18det injectors also? as i have a set of 550's sitting in my room. any help is much appreciated.
d-mag
Road Track Rally
Vehicle: ND - Turbo
Injector help!!!!
Postby d-mag » Thu Dec 17, 2009 8:08 am
Nissan GTR or Mazda Familia GTR?
MX5 Wanted. SE or NC (forced induction preferred :twisted: )
Shinigami!
Injector help!!!!
Postby Shinigami! » Thu Dec 17, 2009 5:47 pm
oh, qhwn peoplw mention gtr i presume they mean skyline. butin saying that i've heard people using 13b injectors? i know ca18det can run 13b injectors so would i be able to use ca injectors for the miata?
Adam_NAclubman
Injector help!!!!
Postby Adam_NAclubman » Fri Dec 18, 2009 2:25 pm
Yes, but they have different plugs so you'll need to swap yours or get adaptors
Shinigami!
Injector help!!!!
Postby Shinigami! » Fri Dec 18, 2009 6:15 pm
thanks for the big help. yeah, i'll be going down the aftermarket map ecu path. so i'll get plugs swapped and what not. many thanks! =]
