Is the BP motor an interference motor?
rob323
Postby rob323 » Wed Aug 12, 2009 7:46 am
I know (from experience unfortunately) that the B6 can lose a timing belt or break the end of the crank without smashing valves, but now that I have an NA8 in my driveway, are the BP motors the same, or are they an interference engine?
Rob.
Don't drive it........RALLY it!
JBT
Postby JBT » Wed Aug 12, 2009 8:27 am
1600 and 1800 are both non-interference.
rob323
Postby rob323 » Thu Aug 13, 2009 8:37 am
Thank you, that's what I thought.
From an Ebay add for a timing belt kit:
It is VITAL to perform this service every 100,000k's on your mx5. If the belt breaks you could do signigicant damage to your engine cylinder head.
JBT
Postby JBT » Thu Aug 13, 2009 9:48 am
True for some cars but not the MX-5. That's Flea Bay for you.
greenMachine
Postby greenMachine » Thu Aug 13, 2009 2:39 pm
JBT wrote:1600 and 1800 are both non-interference.
That is for a stock engine of course.
Long duration cams, shaving the head, decking the block will change that. Then again, those sort of mods would probably entail a new belt also, and what is the betting that on an engine like that there is a teardown inside the next 100 000 kms too ...
:mrgreen:
rob323
Postby rob323 » Thu Aug 13, 2009 4:33 pm
The unfortunate part is that the seller on Ebay would definately know this yet they went and put that quote in the add :roll: .
