1. There was a small oil leak from the CAS "O Ring" a couple of months ago when i adjusted the timing, this ring was since changed but there is still oil sitting at the bottom of the sump/motor that i can see when the car is on a hoist. This oil leak is still there i beleive, i check under the car every few days to see if there is oil leaking, it never drops any oil, there are no spots in any place i park for long amounts of time but my front subframe brace always has a thin glaze of oil
2. The little rubber tube running from the right hand side of the rocker cover to the intake pipe is slightly split at the rocker cover joint.
3. The leaking oil at the bottom of the bottom of the motor gets hot everytime i drive and creates the smell? (this is a guess)
There is no loss in performance as far as i know and the temp gauge sits happily where it should normally be all the time, the oil pressure gauge is correct and normal and oil levels are fine. I cant think of anything that could be causing this...
The car in question is a 1989 NA6 with a B6 Longnose motor in it with around 60,xxx kms.
Thanks Guys, I hope this isnt anything serious....
