Beg, borrow or buy NA8 ECU for onging running problem
d-mag
Road Track Rally
Vehicle: ND - Turbo
Postby d-mag » Tue Apr 14, 2009 9:04 pm
Update your profile with a location. It'll probably help.
I've got one I'd happily lend you, but I'm not sending it interstate.
MX5 Wanted. SE or NC (forced induction preferred :twisted: )
d-mag
Road Track Rally
Vehicle: ND - Turbo
Postby d-mag » Wed Apr 15, 2009 4:01 pm
What year is yours? If the model year doesn't matter to the ECU, I'll help you out.
You can borrow mine mate, but I'll want it back. Doesn't have to be right away, but I do want to keep it.
I'd hate to find myself in your predicament and not be helped out.
Pm me and we'll work it out.
Daz
bigdog
King of the kennel
Postby bigdog » Wed Apr 15, 2009 7:23 pm
Cleaned the throttle body and idle adjustment screw? I'm in Darwin this week, but don't have any MX5 stuff with me :( I could buy you a drink though :D
Postby 93_Clubman » Wed May 13, 2009 2:09 am
CONTI wrote:...when cold before full running temp will stall, need to pulse the throttle to keep going and once at full temp runs with out fault ... Once warm runs fine, but takes much effort to get their. It appears to be a very strange fault Anyone had similar issues??
Hopefully this turned out to be the ecu, but if it didn't & it was an na6, i'd suggest one of the two coolant sensors at the rear of the head, but as it's an na8 i'd suggest looking for an air leak that's intermittently presents when cold. Last one of these, which happened to be an na6, it turned out to be an air leak in the breather pipe from the cam cover - see 2nd last post of p3 of following:
viewtopic.php?f=29&t=35192&start=30
