Engine Swap and Clutch Replacement ... what else do I need?
NMX516
Postby NMX516 » Tue Nov 25, 2008 11:38 pm
Worth replacing the thermostat, and I'd have a close look at the alternator and regulator and also the starter motor...
Might as well do the fuel filter too. :)
SuperMazdaKart
Postby SuperMazdaKart » Wed Nov 26, 2008 12:03 am
how many k's is on the donour engine & what does it have on it?
if it still has it's timing belts/& other belts on & they aren't near the due replacement date then i'd be inclined to leave them on which would save you a timing belt change & few other parts that go with it. otherwise could re-use the belts from the retiring engine if they have enough kilometres in them to last till the next engine change. just don't twist/bend the belts.
my engine swap list is at http://www.mx5cartalk.com/phpBB-3.0.2/viewtopic.php?f=18&t=32405&p=416932&hilit=nb6#p416932 but not all of it would apply to yours.
& make sure to be particularly careful with the heater hoses going into the heatercore.
Matty
Postby Matty » Wed Nov 26, 2008 9:18 am
front and rear gearbox seals.
fattima
Postby fattima » Wed Nov 26, 2008 10:44 am
Rubber blanking plug on back of engine, I'd tap it and use a hex plug while the engine is out.
Postby Mr Morlock » Wed Nov 26, 2008 12:51 pm
If the engine you are intending to replace for a a short period ( how many KM's are you doing) is in reasonable condition I would be doing just the minimum. The planned maintenance thing- ie replacing parts that are ok can get out of control- refer Supermazda's comments. Clutch is of course probably essential. I would leave the bolt on "accessories" alone. But its your money.
Steampunk
Postby Steampunk » Fri Nov 28, 2008 11:18 pm
Check the 2 thin coolant hoses that run from the back of the engine towards the front via underneath the inlet manifold. If they look ok leave them, but if you feel the need, then this is the best time to get to them.
Even though the donor engine has low km's, if it has been sitting unused for a lengthy period, then perhaps add the water-pump to the list as the seals perish due to lack of use.
JBT
Postby JBT » Sat Nov 29, 2008 5:21 pm
Flywheel spigot bearing if it's not included in the clutch kit.
mr_rotary
Postby mr_rotary » Sat Nov 29, 2008 11:03 pm
1red5 wrote:Check the 2 thin coolant hoses that run from the back of the engine towards the front via underneath the inlet manifold. If they look ok leave them, but if you feel the need, then this is the best time to get to them.
Don't forget the little rubber nipple on the back of the block on the driver's side! Only a 40c part and if you got the engine out, so much more easier to replace!!!
ASE05
Postby ASE05 » Mon Dec 01, 2008 7:37 pm
mr_rotary wrote:Don't forget the little rubber nipple on the back of the block on the driver's side! Only a 40c part and if you got the engine out, so much more easier to replace!!!
Can you translate that into mazda OEM speak for me? :lol:
SuperMazdaKart
Postby SuperMazdaKart » Mon Dec 01, 2008 9:39 pm
some alcohol for afterwards?
sabretooth
Postby sabretooth » Tue Dec 02, 2008 8:12 pm
List looks pretty good to me. If I get off my lazy ass I'd get my site up so you can see what I did when rebuilding my engine - to see if you missed anything.
Sounds pretty well-covered to me though.
