I gave the car a bit of a service today. Dropped the diff oil and about 900ml came out, it looked well overdue for a change so good thing I did.
Only problem was that I could only get 500ml back in there before it would come back out the filler, is 900ml what is supposed to go in there?
I don't want to go driving it long distances if it's way under full? How much fluid have some of you guys put in there, I wasn't sure how else I could get more in there?
NA6 diff fluid change
- hot rod
- SuperMazdaKart
on flat level, when it starts coming back out the filler hole then it's full to the amount it should have.
it was probably filled on a downward slope last time?
