aluminium flywheel torque settings
sweep77
Postby sweep77 » Mon Mar 31, 2008 1:02 pm
anyone with aluminium flywheels, what torque do u set the flywheel bolts at? its for a 1.8 1995 mx5
wun911
Postby wun911 » Mon Mar 31, 2008 4:18 pm
The new flywheel should should come with the instructions on how much torque to apply??
every ounce counts
sweep77
Postby sweep77 » Mon Mar 31, 2008 5:22 pm
yeah but i bought it second hand, not new.
CT
Postby CT » Tue Apr 01, 2008 6:37 am
Same as a regular one I would suspect. Check miata.net's garage section for torque settings. Make sure you clean the bolts and threads and use threadlocker.
CT
Postby CT » Tue Apr 01, 2008 6:38 am
fattima
Postby fattima » Tue Apr 01, 2008 9:34 am
Also can I add check the thickness of the flywheel where the bolts go through and make sure it is the same as the old one. I used an alloy flywheel on an engine and the bolts bottomed out but felt like they had torqued up. Funny noise on the engine dyno and flywheel lets go on the run down, damaged the block as it came off and left a nice graze in the dyno room wall :shock:
This was not on a mazda engine, but can't hurt to check.
