How do you keep it down? The headers are already ceramic coated but the airbox, heater hoses, and nearby wiring are still getting disturbingly hot and smelly. I've refitted the extinguisher for daily driving.
Has anyone got experience with header wraps or exhaust wraps or heat blankets or anything else that works?
Header heat
Header heat
- Steampunk
I put heat-reflective tape, which is same as header-wrap but with a metalised surface one side and sticky on the other, on the heat-shield protecting my pod and it works only if you put at least 2 layers on/around the part you are protecting.
I also have it on the heater hoses, and a hydraulic hard-line near the headers. But what I did is wrap foil around the hoses first and then reflective wrap around that.
There's a corrugated aluminium panel made by ACL that works very well at deflecting and dissipating heat. NMX516 has one, as do a few others.
- fattima
Have heard many negative stories about exhaust wrap, mainly manifolds cracking.
Saw this the other day, looks interesting
http://www.trackdogracing.com/website/heat_shields.htm
- pcmx5
- Vehicle: ND - 2
fattima wrote:Have heard many negative stories about exhaust wrap, mainly manifolds cracking.
I have used exhaust wrap on my current system with no problems over two years,but have the Track Dog shield in the garage waiting to go on when I change to RB headers;it doesn't sit directly on the headers,leaves space to aid flow.
Sorry probably won't do the change for a couple of months so cannot promise a "roadtest" soon!
Peter
- Vehicle: NA6 - Turbo
Manga_blue I can strongly suggest using the corrugated aluminium panel by ACL, it's a bit pricey ($70 for 700mm x 300mm sheet) but it works as it has a ceramic fibre insert. I ahev just installed it on my turbo application and the bonnet no longer gets hot!
I can also recommend using silicone hose covers on those pipes that are constantly near any hot spots such as exhaust manifold. Some speed shops will have the silicone hose covers and the colours are red or a light grey - I got mine from OG Speed Shop in SA, also a bit pricey at about $30 per metre but great stuff.
I can send pic's if you like to show you what I'm on about if you wish just PM me oyur email address.
Thanks guys. I think I've got it worked out and I'll use everyone's advice. That means:
1. I've ordered the Track Dog bag, thanks Pete and Bruce
2. I've bought the reflective tape, thanks Andrew, to cover the power steering hose, the really hot part of the airbox, the centre radiator hose and the heater hose until the Black Dog thingy arrives.
3. I'll swap to silicon hoses (not just sleeves) all round later in the year when I come round to a preparing for an enduro again.
4. If steps 1 and 2 are not enough then I'll form the ACL sheet between the airbox and the headers, curving itaround towards the firewall to separate them from the heater hoses.
Aren't forums great!
- Steampunk
- sabretooth
