Changing shift lever boots and shift bushes any hints?
JBT
Postby JBT » Sat Feb 16, 2008 9:00 pm
I never replaced the turret oil in the NA. I did over fill it when topping it up....which I thought I needed to do but, in retrospect, didn't need to do. If you can see some oil in there it's all OK.
TieNN89
Postby TieNN89 » Sat Feb 16, 2008 10:07 pm
i replaced mine before didn't have much in it barely any actually
so i sucked it out and replaced it with some new stuff
and changing gears were slightly better :D
JBT
Postby JBT » Sun Feb 17, 2008 6:52 am
Why did you ask the question if you already had your own answer?
TieNN89
Postby TieNN89 » Sun Feb 17, 2008 10:23 am
no i meant i just replaced mine as in an hour ago lol
Postby manga_blue » Sun Feb 17, 2008 4:00 pm
davamb wrote:And one from me on this topic if I may...
I changed my shift bush over to a new brass one over the weekend (shift much better now), but buggered if I could get the gearknob off, both top and bottom boots are split and knackered and need to be replaced - what's the story, am I just too wimpy?
Where do you get a brass one from?
