Oil for a Torsen
Oil for a Torsen
What do I use? I'm fairly sure I had to use a different oil to the stuff normally used in Viscous LSD's for the mechanical diff in my DR30, so I'm unsure of what type the Torsen needs?
I'm using a Castrol oil in my Torsen diff. The bottle is labeled as being for Limited Slip Diffs. Took around 1 litre from memory.
I'm pretty sure it was this one.
Castrol LSX 90
Mineral gear oil recommended for cars and commercial vehicle axles operating under higher frictional loads, especially limited slip differentials and those experiencing clutch chatter. Meets Mack GO-J quality thermal stability requirement. SAE 90, API GL5.
J
Castrol LSX 90
J
- JBT
- Lucky_Luke
