A quick question for the aftermarket turbos among us - what oil are you now using, and how's your oil pressure at full operating temp?
I'm using the Castrol oil for 'hot 4's and turbos' - comes in a gold coloured container. I just noticed the other day that my pressure at idle once warm is a bit lower (about the 1 mark) than it used to be pre-turbo (just less than 2) - it is fine at startup, so the oil is thinning a bit when warm (obviously). Pressure when driving is normal - just under 4.
What are others using/getting?
Oil for turbo 5's - what are you using & how's pressure?
- Uncle Arthur
- Dodgy Award Benefactor
- Location: Doesn't matter where I'm from-it's that your daughter is with me that's the biggest concern :D
- ampz
- Vehicle: NA6 - Turbo
I have Havoline Semi Synth 15/50 from Big W
I get just on or over 2 on idle (depends if AC is on or not) when hot.
It is a lot quieter that it was before (read lifter noise, it sounded like it had a diesel factory option on mine
I was using Magnatec 10/40 before (pre turbo).
I'm very happy with the Havoline, but it is only freshly changed.
PS: It was under $30 too
Huh?
Mobil 1 - 5w-50
Just below 2 when on idle, around 6 at higher revs before completely warmed up and closer to 4 once warmed up.
Not burning any oil and it seems to be staying pretty clean between changes. I try and buy the oil when super cheap is having a sale.
J
J
- Boags
Motul Turbo-Light (which they don't make anymore...
I have the same characteristics as you UA.
Boags
Boags
- Sean
- sabretooth
