Just blew a heating hose....
MVZOOM
Location: Road signs are so hard to read when you are driving quickly....
Postby MVZOOM » Tue Oct 17, 2006 3:09 pm
Guys and gals,
One of the two hoses which go from the rear of the engine through the firewall (I'm assuming they're for the heater) has developed a nasty drip on the engine side.
Does anyone have a part number for these?
My intent it to remove it this evening, cut a bit off it, re-clamp and get to a Repco / Mazda joint and grab a new one. Any problems with this plan?
BTW - it's a '97 NA 1.8.
Cheers - Mike
EDIT _ is a better plan to remove both in and out hoses, and connect the in and out ports on the engine together, using one hose, bypassing the heater?
'97 LE [R.I.P] - 240kW Mazda3 MPS, BMW E46 M3, Lotus Exige S
JBT
Postby JBT » Tue Oct 17, 2006 3:16 pm
Good luck getting a replacement today.
Make sure you carefully cut the hose off the very fragile pipe at the firewall.
Beware that the heater is an integral part of the cooling system.
john!
Postby john! » Tue Oct 17, 2006 8:05 pm
If you have had a heater hose let go, best to check the back of the head around the CAS for oil leaks if you haven't done so already. The oil slowly kills the hoses, so I would be wary of driving too far or too long with the old hose in place. I ended up buying a meter of generic heater hose and bypassing the heater core until I could replace the hoses. Although how mazda can justify around $50 for 2 pieces of rubber I will never know. It also took 2 days to get them shipped up to Brisbane. YMMV, I elected to replace all the other 13 year old hoses at the same time.
john!
mickfred
Postby mickfred » Tue Oct 17, 2006 11:10 pm
JBT wrote:Good luck getting a replacement today.
why is it so integral?
YEAH BABY!
Matty
Postby Matty » Tue Oct 17, 2006 11:13 pm
not the heater per se, but the routing of the cooling around the back of the head relies on having that flow path open. At a minimum you need to route the hoses to each other.
JBT
Postby JBT » Tue Oct 17, 2006 11:26 pm
I was also told it was required for coolant volume.
jules
Guitar Hero
Postby jules » Wed Oct 18, 2006 10:02 am
Mike,
I'd get both hoses. It can be a bitch of a job and you'll probably end up cutting off the hoses with a Stanley knife.
Do check the CAS area for leaks while you're at it. With mine, I smeared a tad of grease on the replacement hoses where they attach to the heater core fittings.
I got mine genuine from Mazda.
Jules
Postby bruce » Wed Oct 18, 2006 1:12 pm
...as long as you didn't just blow a seal.... :mrgreen:
Curly
Postby Curly » Wed Oct 18, 2006 3:15 pm
\"It was an icecream!\", said the penguin.
MVZOOM
Postby MVZOOM » Wed Oct 18, 2006 3:21 pm
jules wrote:Mike,
Jules
Thanks JUles. Actually popped it up to Mania this morning, as I couldn't find 1/2 the tools I needed to do the job :evil: .
Daniel sorted it for me, took him about 35mins - would have taken me two hours! It was from a leaky CAS o-ring, that we replaced earlier this year, so at least I know. Total all up was sub $50 for the replacement hose and labour - MX5Mania truely rock!
Picked up a vodoo knob and Benny's boot to celebrate 171,000 k's, as well!
Cheers - Mike
MVZOOM
Postby MVZOOM » Wed Oct 18, 2006 3:22 pm
Cheers - Mike
jules
Guitar Hero
Postby jules » Wed Oct 18, 2006 3:45 pm
Cool. I'm still languishing on 125,000kms
Jules
