Thanks JB(T) - You've done it again :)
Uncle Arthur
Dodgy Award Benefactor
Postby Uncle Arthur » Wed Oct 04, 2006 10:43 pm
Looks like the clutch is fixed and working. JBT dropped by tonite and helped me ascertain exactly how much clutch actuator travel I was getting, and where it was taking up.
Adjusting both the clutch takeup point and clutch height has given me full clutch pedal travel, and a disengage point about 1/2 way towards the bottom of pedal travel and take up at about 1/3 of the return travel.
Pedal pressure is a little harder than standard, but it bites nicely :)
r0gue
Postby r0gue » Thu Oct 05, 2006 11:15 am
When you say actuator travel, take up point and clutch height what exactly are you referring to?
sabretooth
Postby sabretooth » Thu Oct 05, 2006 11:27 am
You hadn't tried adjusting the stud on the pedal to start with (which goes into the master)
Great to hear it's working though.
JBT
Postby JBT » Thu Oct 05, 2006 11:56 am
r0gue wrote:When you say actuator travel, take up point and clutch height what exactly are you referring to?
Pics from my car.........hmmmm..... 11 years of brake fluid mist there.
Clutch switch adjustment changes pedal height and pushrod adjustment changes freeplay.
After UA adjusted things, there was an extra 3mm of slave pushrod travel which made a big difference to the pedal height at clutch engagement.
jules
Guitar Hero
Postby jules » Thu Oct 05, 2006 12:46 pm
So, can we say the clutch replacement was a success now?
Jules
Uncle Arthur
Postby Uncle Arthur » Thu Oct 05, 2006 10:14 pm
jules wrote:So, can we say the clutch replacement was a success now?
Jules
Can I touch wood??? :D (and that's enough out of you wayne!!! :shock: )
It seems to be working well - I'll check that there's no leakage on the weekend, but it feels good to drive.
Uncle Arthur
Postby Uncle Arthur » Thu Oct 05, 2006 10:20 pm
sabretooth wrote:You hadn't tried adjusting the stud on the pedal to start with (which goes into the master)
I had done so a couple of times, but I hadn't gone as far as the pedal height - what isn't immediately obvious is just how much those two factors actually rely on eachother with the higher pressure clutch. I'm thinking now it actually needs much more travel than the standard item.
Users browsing this forum: Bing [Bot] and 3 guests
