Matching wiring connectors
petdow
Postby petdow » Wed Apr 12, 2006 11:02 am
Hello All,
I hope someone out there can impart some knowledge. I recently purchased my first MX-5 (1995), and I have found a couple of wires with connectors that seem to be made to fit each other. If someone could advise what the wires power/control and whether I should connect them.
First, a female connector that seems to be coming from the ignition key lock, two wires - Red/Yellow Tracer and Green. Seeming to match this is male connector coming from a loom, two wires - Blue/Violet Tracer and Blue/Yellow Tracer.
Second, under the drivers seat, a male connector, three wires - Black, Blue/White tracer, White/Red tracer. Seeming to match this is a female connector, three wires - Black, Blue, Red.
Any ideas would be appreciated.
Peter.
CT
Postby CT » Wed Apr 12, 2006 12:05 pm
Garry
Postby Garry » Wed Apr 12, 2006 12:35 pm
Possibly the buzzer for the seat belt? Does the seatbelt light on the dash illuminate when the seatbelt isn't plugged in and the engine is running?
petdow
Postby petdow » Thu Apr 13, 2006 8:43 pm
Thankyou Garry and CT for your replies. Garry you were correct about the seat belt light for the wires under the driver's seat. CT, using the link you posted I able to establish the wire from the ignition was for a \"key left in the ignition\" warning buzzer. Thanks again guys, Peter.
Users browsing this forum: No registered users and 48 guests
