wastegate signal line relocation = MORE BOOST
Babalouie
godfather of saké
Postby Babalouie » Sun Mar 12, 2006 1:52 pm
You haven't linked to the thread mate :D
PT
Postby PT » Sun Mar 12, 2006 2:03 pm
I think he's talking about this one:
http://mazda-speed.com/forum2/index.php?topic=2896.0
Past:
2005 Mazda MX-5 SE
1991 Mazda MX-5 NA6
Sean
Postby Sean » Sun Mar 12, 2006 6:31 pm
Why not just put a simple bleeder vcalve in if you want more boost?
Woo
Vehicle: 10AE - Turbo
Postby Woo » Sun Mar 12, 2006 10:04 pm
Aren't you robbing vacuum/boost by using a bleeder valve? They bleed to atmosphere.
Your better off adjusting the wastegate linkage..... it enables you to attain another 1.5-2 psi without loss. Only hassle is if the dodgies have had a go at the linkage there often isn't the throw to keep the WG closed at low boost levels while gaining the extra up top.
Boris, you'll need to be really careful of your EGT and AF if you hold the WG closed at high revs man. One reason why the WG is there is to lower crown temperatures to avoid melting pots or burning valves.
Additionally, the highest vacuum will be in the TB due to the venturi effect.
Wòó
Very slightly modified 10AE #2562 ..... one of 149 in Australia :wink:
Race what you brung ..... And hope you brung enough
Benny
Postby Benny » Mon Mar 13, 2006 10:17 am
On my SP, I've re-located the vaccum/boost line from the exhaust maifold to the inlet manifold so that it reads boost after the intercooler instead of before the intercooler.
It does seem to have a little more low down boost, but the top end stays about the same, although my boost gauge does indicate I'm getting an extra half a pound boost.
The wastegate is now louder, for some reason, and throttle has become jerky when declerating while under boost.
In the end, I think it drove beeter with the line in it's original position, but there may be a smidgen more power the new way.
Sean
Postby Sean » Fri Mar 17, 2006 7:55 pm
Woo wrote:Aren't you robbing vacuum/boost by using a bleeder valve? They bleed to atmosphere.
No because you will be increasing boost. the bleeder bleeds air out of the line that signal the actuator to open, which resuls in the actuator opening later.
Yes you will lose a small amount of air (less than 1.4 cfm) but the extra boost will make it unnoticeable. Even at the same boost you will make the same power. AT vacuum no air will be gained or lost.
