Soft top window
Soft top window
Looking to see if my plastic soft top window is repairable. Was left out in the sun when I sent it to have engine upgraded.
Re: Soft top window
From the pic that window appears terminal - Meguiar's Plastx is what we always used to recommend: https://www.meguiars.com.au/product/plastx/
- bruce
- Vehicle: NA8 - Turbo
Re: Soft top window
Desperate, but you could try a tiny test patch with a fine metal polish like Silvo or Purple if you've got some
- bruce
Re: Soft top window
I think it depends if the cloudiness is on the surface or throughout the plastic? Looks like the latter which is no good.
Re: Soft top window
bruce wrote:I think it depends if the cloudiness is on the surface or throughout the plastic? Looks like the latter which is no good.
Yeah, mine was a nothing to lose sort of suggestion
- Vehicle: ND - 2
Re: Soft top window
Hi.
Try brasso its the product to clean and polish plastic headlight covers . Not a bad product been around since 1904.
